Dieudos123
Hello everybody on this forum!
I have the problem maybe on the aperture for avantra 30E.
In fact I print the job from the RIP or if I do internal test page
from the machine the result is the same:the image is not clear!
Especial when I do that in 2400dpi.When I removed the carriage so that I check on SGM,I found that on aperture the
1800dpi hole was selected even if on the machine the 2400dpi was selected!I tried to change the resolution on the machine many times but the aperture position doesnt change!As the service manual tells each resolution has its
hole on the aperture when selected.The biger for 3600dpi the smallest for 1200dpi.What can cause this?
Thank you.
Thank you.
