Booklet problem with KM 6501
DPGate
Greeting ,
iam trying to print booklet by fiery software . its ok just for max 6 pages . but more than this
it take long long time processing and then didn't print .
the file is pdf .
so why it take very long time to process and then didn't respond .????
The long processing time was likely caused by large amounts of transparency and graphics used which needed to be processed by the RIP.
If the job failed to print, you may have conflicting settings; "Fold" combined with "Main" Output Tray (although the print features window would usually alert to this conflict).
The size of the RIP'd postscript probably became to large for the system memory.
Try to duplex pages 1&2 followed by pages 3&4 followed by pages 5&6. That would eliminate the question of a possible bad pdf source file.
You could flatten the transparency in the pdf, that would speed up the spooling (save a Press or High Quality pdf as opposed to x1a)
ok I will check this .. by the way .. i found on efi website someone was have sam problem and upgrade memory in controller and work faster than before ..
Is this available in machine KonicaMonilta 6501 controller ??
