Steamroller
Hello,
I am new to the forum. I have a Challenge MC 305 cutter that has the blade stuck in the down position and will not come back up. This happened a couple of months ago and I used compressed air to blow the switches out. It then worked for a couple of weeks and did it again. I then replaced the switches and contactors in the switches. A month later the same thing happened. Was it a coincidence or do we have something else going wrong?
The motor runs when you turn it on, the pump pumps and tries to put the blade down when you press both switches in but once you let off of the switches the blade should go back up but the pump does not even try to pump the other direction.
S#8546
Mustard yellow
Microcut Jr
Any help would be appreciated.
S#8546
Mustard yellow
Microcut Jr
