Color Management Generate Profiles ICC
celiano88
I'm using the Kaleidoscope to print in Indigo HP WS4500.
I would like know the currect process for generate the Profiles ICC, and read with i1 in Kaleidoscope.
* Where generate the Profiles ICC straight to HP?
* Where I read with i1?
Thanks,
Celiano
Celiano, did you not receive any training from your vendor or a color management consultant on this process? I would start with whoever sold you this equipment and see if they can review this process with you.
Regards,
Terry
OK. Terry
I'm begotten the ICC, but I could not read with spectrophotometer automatically, only one color at a time. At the configuration of generation may be wrong?
Regards,
Celiano
Celiano,
Somewhere in your setup procedure, there will be an option to use the i1 in strip mode, or in patch mode. You need to find it and set it to 'strip' to resolve the issue you're having.
However, and as Terry alluded to, quite frankly if you have to come online to ask that, the learing curve you're facing to actually get usable results is so daunting you really, really do need to hire someone to come train you.
Mike Adams
Correct Color
