I have some questions about the use of color profiles when preparing images for different printing conditions.
I have a customer supplied image which is CMYK. It may or may not have a profile and if it does, the profile is probably SWOP or GRACoL. It probably started out as RGB, but who knows how it was converted to CMYK.
I'm going to print this image on an offset press on uncoated paper. I realize that it will loose saturation and that the darkest color will be lighter than what I could get on coated paper. I have done the G7 process on this press for this paper so I have a good profile that describes how it prints and I have a good proof that matches the press sheet.
So I run a proof of this image and the proof looks flat like it should because it is accurately predicting what the press sheet will look like. And I'm getting complaints from the customers and salespeople because the proof looks so flat.
Next I color correct the image to add contrast and saturation. Even though I can't completely fix the problem, there is usually a definite improvement. The new proof looks better, and the press run matches the new proof.
What I want to know, is if this problem can be compensated for by the correct use of profiles or am I always going to have to do manual color corrections.
Let's say I start with the original RGB image which has a correct RGB profile. I then convert it to CMYK using the uncoated press profile. Or I start with the CMYK image and convert to the uncoated press profile. Is there something built into this process that will at least partly compensate for the loss of saturation I will get on press? Or is this just adjusting for different Lab values of the colorants?
I think I understand the concept of using a profile to simulate the uncoated paper on the proofer. That's like saying "Here are the original pixel values, change them to what they would look like on the uncoated paper".
I'm much less clear on the non-simulation use of profiles to convert from RGB to CMYK or from CMYK to CMYK. Obviously, I don't want that conversion to be a simulation. I think I want it to be an anti-simulation. "Make these pixels into something that will look close to the original once the simulation (or the actual printing process) is applied to them. Do I have that right?
