comparision/ difference between Cron CTcp and Amsky Ctcp
K
kala
Guest
Hi
Can anyone provide the details or difference between Cron CTcp & Amsky Ctcp & Luscher uv ctp
regards
kala
i need to know the advantages and disadvantages of both ctcp (ie comparision)
Here are electron-microscope images of plates from 3 CTCP systems compared to a thermal plate made on a Kodak SQUAREspot device.
You'll notice the difference in control/sharpness at the dot edges. This is due to the gaussian profile for the laser spot on CTCP (and non-SQUAREspot thermal devices), resulting in the edge exposure gradually fading instead of being cleanly cut off. That partially-exposed area is what's most sensitive to variation - in plate speed, processing, exposure, and other normal factors.
For coarse screens you won't see much effect from this - because the ratio of that "soft edge" to the size of each dot is pretty small. But once you get above 150lpi, the proportion of each dot that is "soft edge" grows considerably. This means you'll see more and more density change due to those variables as your screening goes up, and SQUAREspot will see considerably less (yes, we have data to prove that).
These were from plates I gathered personally from active user sites (mostly in Asia). What was interesting to me was that some of the systems had "reasonable" control in one axis (slow scan), the other axis was horrible. This causes another problem - as your variables change, you'll get a different level of effect on horizontal lines than you do on vertical ones. That can affect text as easily as it can screening or graphics.
Kevin.
basysPrint says that only a basysPrint UV-Setter is able to image a 1-bit-Tiff one-to-one on the printing plate and that another unique design feature of the UV-Setter is the tiny, square pixel generated during exposure having extremely sharp edges.
Attached are electron microscope photo and visible light photo of basysPrint plate that they show. They look pretty sharp to me.
FL
Can some please advise me if the HP indigo 3050 digital press could be install on a story building first floor or if anyone had seen some installed upstairs in the past and recent. a quick and right answer will really be appreciated. I just took delivery of one and i needed to be guided to avoid future quandary. thanks to all.
