I've been having some problems with the Creo and KM 6500.
- When impositioning with the Creo, any size 4x6 or under, has a problem recognizing the bleeds. The Creo will think the bottom bleed is part of the document, and that the top bleed doesn't exist. So my crop marks will be .125 off and finished trim product will hence be off-center by .125 (along with having no bleed on top).
I had a tech in here and he had no clue what I was saying, and didn't understand the problem. He blamed my properly made PDFs (with INDD crop marks), then suggested I change the trim size for a business card from 3.5 x 2 to 3.75 x 2.5. That made my INDD crop marks show instead of the Creo, so he said it was solved... adding a fake gutter so I get less-up is a work-around not a solution.
Calls to service manager are unreturned so I turn to you.
- When printing imposed sheets (imposed on Creo or elsewhere), the image seems to shrink. 4x6 cards will become 3.95x5.95, 8.5x11 will become 8.4 x 10.9. This isn't really a big deal, but it's annoying when I have postcards and I cut 6 inch, 6inch, 6inch, and then the last one ends up being messed up because I didn't realize they became 5.95.
- When printing on 13x19, the image is sometimes off-center... using the Creo to shift the position of the image results in the lead edge of the image being cut off. Even though there's still .375 margin existing. So there will be a blank .375 margin, then the image will start but will be cut off.
This doesn't involve the Creo:
- When printing on 12pt, about 2 inches from the trail edge, I get a jitter, or a .25 area where it seems like the paper got stuck and then started again. The image blurs or registration is off, then it goes back to normal.
This sounds like alot of complaints.... Whoops.
