CREO Imposition
onlyinajeep
We just got a Xerox 8000AP with CREO (CXP8000 v3.0sp2). This is our first exposure to CREO, previous cut-sheet printers were FreeFlow. We're not having much luck with the imposition feature.
We are trying to print a letter sized document on tabloid form imposed to a saddle stitched booklet layout. (partial Job ticket below, full job ticket attached). The preview shows everything fits on the sheet and is imposed in saddle stitched booklet order, but the job always fails in processing with this error, “Imposition layout exceeds the boundaries of the selected paper size. Please change imposition parameters, or adjust their values”. :confused:
-Steve
job ticket:
===== Print Settings =====
Print Mode Composite
Number of copies 1
Print range All
Print method Duplex head to head
Print order From 1 to N
Delivery Face up
Collation Yes
Image position 0.0,0.0,0.0,0.0
Image scale 100%
Rotate 180 No
Gallop No
===== Paper Stock =====
Paper set name VA-5476
Paper size Tabloid
Media type Paper
Weight 81-105 gsm
Coating Uncoated
Tray Auto
Mixed paper size No
===== Imposition =====
Imposition method Saddle Stitch
sets per sheet: 1
Sizes
Paper set VA-5476
Trim size Letter
Orientation Portrait
Template 2X1 DUP Rotated
Margins
Margin size 0.0
Gutter size 0.0
Spine trim size 0.0
Marks & bleed
Marks
Bleed Maximum bleed
Creep
Creep in 0.0
Creep out 0.0
Scale Scale by: 100.0%
  • Booklet_tic.txt
Is there bleed in the original file - if so set the bleed value to what is is the file
The file is a simple, letter sized .pdf...no trim/bleed/crop/media boxes.
You can use an easy to use Imposition plug-in for Acrobat, like our "Absolutely Imposing". It's only $450 and available for MAC or for WINDOWS. It is not RIP dependent so you can use it for all your printing devices.
A demo version is available on our Web site Loading dynamic Web site: Ultimate Technographics Inc. ...
Ray Duval
It looks like what you are trying to impose is letter size. Perhaps the imposition is trying to allow room for marks or bleed making it larger than 11 x 17. You might try creating an imposition that is smaller than letter (7x9 or some such) just to see if that works. If you get the smaller size to print you might see that there are indeed marks applied and you can also work your way up in size until it says it won't fit. This might help you figure out what the problem is.
Steven
Ray Duval
@ Ray - you crack me up. No matter what the question is, you answer is always "don't use what you have, buy our product"
@ Onlyinajeep - My guess here is that there are either some margin setting given the error message - or perhaps - for Orientation - you have portrait instead of landscape ? Probably something simple like that.
Maybe make sure all the pages of your PDF are the exact same size (specifically the Media Box). Pitstop can do this.
I have been trying to remember this from when I ran the same machine.It has been a while.I remember that we had to play with imposition and even lie to the machine to get it to work. Don't always go by the diagram that shows whether the sheets will fit or not. When you are having problems while using imposition I found that our problems could be any of the following:Cut size was wrong (set too large or too small).Template should be 1 x2 instead of 2 x 1, 2 x3 instead of 3 x 2 etc.
Does not need to rotate if set to rotate and does need to rotate if not set to rotate. Should be landscape instead of portrait and vice versa. Paper size is set incorrectly in imposition (when using imposition the paper stock settings are overridden by the settings in imposition ).
When trying to figure out your problem make only one change at a time. In this case the first try changing your cut size to tabloid or none if available.Then if that doesn't work then change it back to letter.Then check your template,next rotation,then orientation.
This is a really good program which can even save settings so that you don't have to enter your settings every time for the same type of jobs. Check with your xerox analyst or technican to teach you about this program.
