Cyrel Plate Material Cracking...
prepressbb
Does anyone here use Cyrel Plate material? And has anyone ever encountered a problem with it cracking on the surface after a short period of time?
your feedback will be muchly appreciated.
What kind is it, DPL, DPR, FHM, EXL, TDR and what thickness? Look at your dry & curing times, maybe they need to be reduced. Sometimes the wrong solvent used to clean the plate will make it crack after it is run a few times. Are you getting any delaminating issues?
it is Cyrel DFM 112 full digital plates. So its developed thermal. No delaminating issues. NO SOLVENT. i would check my times, but as far as that goes the times are as to what the manufacturer recommended.
