color_prepress
My CTF is herkules Pro.
I using delta tower with delta rip 8 on windows 2000.
All work well until last week the delta tower got error message come out.
Delta Tower:error during delta tower configuration.
At start we found out is scsi harddisk problem in delta tower, so we had order a same model scsi harddisk(set the jumper correctly follow previous one) to replace it. (We even doing low level format on it and it able to format so can confirm that the harddisk is ok)
After that we though it should be able to run but after tried, it still failed.
We had tried so many things but problem still exist. Here is the sequence that we tried.
At first replace same model of scsi harddisk into tower.
After that we manage to get another delta tower from other people to tried but still fail.
Then we tried switching another scsi cable that connecting delta tower to server.
We had also tried switching another scsi card in the server that connecting server and tower.
All fail.
So any of you got any suggestion/opinion to fix it?
All fail.
