I am running an older version of navigator (8.1 r3) through a harlequin and am having issues with direct printing through hotfolders from indesign cs6. I set up my screen angles and when it plates the job, all the angles come out on 45 instead of standard angles. When I run the same job through impO2 software, everything comes out correct. I'm not too familiar with the rip settings on harlequins as I came from a Esko/Nexus platform before starting this job but this is frustrating me greatly as I could easily fix this issue in that rip but what I've tried on the navigator settings hasn't solved this issue. There also seems to be a resolution issue as welll as the impO2 files seem to be crisper than when it's direct printed through the hotfolders. The shop I'm at does mainly 1-2 color jobs (line mostly) but occasionally will run a 4 color with screening and impO2 is pretty frustrating to keep making different templates for each size when I could have already had it plated through the hotfolder in the time it takes to make the template in inpO2. Any suggestions or tips would be greatly appreciated.
