Printastic
Hi Guys, I run Tech Lighting UV coater, with 12-14-16 pt cover stock. The stock is so thick that I usually just do not engage the bottom roller all the way and leave a tiny winy gap and do not engage the doctor blade at all and just run it using the top roller only through this little gap I have. This way I don't even need to use / clean bottom roller and the doctor blade at all. But all out of blue I got this thought that maybe I'm putting down too much UV solution this way and coating is too thick? Would the coating be thinner / used less if I engaged the bottom roller to "touch" and used the doctor blade to clean off the excess? Thank you for all your help. Stan.
