Gordon Gordon Gordon,
After all these years, you still don't understand my philosophy on these issues.
Very sad. :-(
Sure one could have technology to inspect and compare all these points in the image relative to the target. Yes it is already here. I am not advocating using such technology. Basically I do not want to have to measure for control. Measure for calibration but not so much for control. Make the process consistent and predictable and then there would be no need to measure for control.
Just because one would have a standard that asks for the matching of points in the images that does not mean that one has to have active control via measurements. If a capable process, that is calibrated, demonstrates that it continually meets a standard of performance, then one does not have to measure it to confirm it each time. It will become accepted by the customer.
Heidelberg's use of image control at the press was not a great thing at all. It is a technology to compensate for not being able to print consistently within the image. Heidelberg's system could not change an area in the print in the image independently of other parts of the image. You pick an area of concern, the system would look at it and compare it with a reference. Then ink keys would be adjusted to satisfy the match in that area but at the expense of other parts of the image in line with that area.
They would never consider putting such a system on the Anicolor press since there is more consistency with the inking of the plate in all areas. Also this consistent inking of the plate means that the profile for the Anicolor press is more predictable.
I would say the standards organizations are damaging the industry for exactly the reason you stated. It is in their interest to do what they do. Now they also seem to be pulling RIT into the mix. Not a good trend IMO. The universities should be independent so that they can have an independent voice. Although I am not sure they are imaginative enough to know what is wrong. I don't think they have done such a great job in this area. Much of the time they act like users of technology and not fundamental researchers of knowledge.
[SNIP]
So, without the Image Control or some other measuring devise, you will probably have a DeltaE of 5 to 6 throughout the run with a very good pressman.
Could you explain exactly what is meant by "a DeltaE of 5 to 6 throughout the run"? What is being measured? What is being compared?
J
Your statement "Make the process consistent and predictable and then there would be no need to measure for control" in the real world, is not possible.
Sorry but you are wrong. You have experience with mainly conventional press design concepts which makes it difficult for you to predict what is possible with different concepts.
How can you say what is possible when every Heidelberg press does not have control of the ink that is delivered to the roller train? No mechanical device on those presses is directly related to the amount of ink that goes into the roller train.QUOTE]
Im speaking for any printing press. If I am reading you right, you are stating "Basically I do not want to have to measure for control. Measure for calibration but not so much for control. Make the process consistent and predictable and then there would be no need to measure for control."
As I said above, "So, without the Image Control or some other measuring devise, you will probably have a DeltaE of 5 to 6 throughout the run with a very good pressman. Without a chilling devise on the Anicolor, we have no control at all." meaning control has to come from somewhere, be it the pressman, materials or a device of some kind.
I
I like the way you think Erik! I really think its good to think outside the box, something good always comes from it!
Thought I'd share what Felix Brunner thinks of color control. I am in System Brunner's Camp, he knows more about color printing than anyone alive or dead! He contends that 80% of print problems are dot related - 20% SID. "What do you measure."
See Attached:
Dan Remaley
412.889.7643
Thanks. I really really hope that it won't take so long to have that capability demonstrated to all. It potentially can give offset a well needed boost in its fight with digital printing presses. Long live offset!
DeltaE is a measurement from the reference (color, OK sheet ect.) to the current measurement.
For instance; A customer OK sheet has a DeltaE of 0, we measure the press sheets to ensure the job stays as close as possible to the OK sheet, DeltaE 0. Commonly, a good run will constitute a DeltaE of 0.8 average. If a sheet has a DeltaE of 2, it is commercially acceptable in most shops in the US, whereas the DeltaE of 5 to 6 is grossly out of the ballpark in all.
Hope I answered your question.
Not quite. When you say you're measuring the press sheets - what exactly are you measuring and summing up with one DeltaE number? Are you measuring the solid ink patches and averaging them? The solids and RGB over prints and averaging them?
J
With Image control, you can read image or the color control strip, so I am using that as an example. The DeltaE can be read as an average of all or one ink zone. The example I was refering to is an average of all ink zones.
