Dumb Illustrator question
  • Thread starter Thread starter J
  • Start date Start date
J
I'm sure there's a simple answer to this - but I don't use Illustrator CS3 very often so I can't find it.
I want to have a 100% Cyan square partially over print a 100% magenta square.
How do I make it do that? "Overprint" seems only to apply to black and not other colors.
Also, can I preview the result in Illustrator?
thx, J
illustrator overprint
no question is dumb . . . in ill cs3 you use the attributes pallet and set the fill to overprint . . . done
to preview it select view . . . overprint preview
Thank you dabob. I made the mistake of searching for "overprint" in the Illustrator help file which, naturally, does not mention the "Attributes" palette.
Sheeesh.
Thanks again, J
