Elliptical vs. Round vs. Square dot shape?
tmiller_iluvprinting
We print most of our 4 color work at 200LS with an elliptical dot shape. I wasn't involved in this decision, and we have been printing like this for at least 10 years. I have been asking why we chose to do this, and of course, most of the responses have been , 'we've always done it like that'. The reading that I have done has explained that elliptical is used mostly for screen printing and other print processes with heavy dot gain. We have problems matching proofs that are made using the official GRACol press data which I believe was run at 175 LS, using a square or round dot shape. The problem that we have when trying to match the GRACol proof is that the 1/4 tones on the press sheet are heavier than the proof. My thought is this may be because of our 200LS and elliptical dot shape. Any thoughts on this? Thank you.
Best regards,
Todd
I found that we switched to elliptical when we installed our film based image setter years ago on the advice from someone that elliptical would lessen visible rosette and lessen dot gain. If we print 200LS I would think that the visible rosette between dot shapes would be splitting hairs. We continued with elliptical when we went to CTP because of legacy work. After reading Gordo's blog(which is an excellent reference-thank you Gordo, thanks Greg for the direction!) the dot shape may the root of some of our issues.
Best regards,
Todd
Maybe a different question, what is the best dot shape for printing 200LS, sheetfed, offset? I have a feeling our use of elliptical is making our job harder.
Best regards,
Todd
Best regards,
Todd
Round dot (a.k.a. non-transforming round dot i.e. non-Euclidean).
BTW it's the dot shape that was used for most (if not all) of the GRACoL 7 characterization press runs.
best, gordo
I found that we switched to elliptical when we installed our film based image setter years ago on the advice from someone that elliptical would lessen visible rosette and lessen dot gain. If we print 200LS I would think that the visible rosette between dot shapes would be splitting hairs. We continued with elliptical when we went to CTP because of legacy work. [snip]
The advice you were given was wrong and/or incomplete.
Elliptical dots don't lessen the visibility of rosettes nor do they lessen dot gain (which can easily be compensated for with a curve applied to the plate). What the person was probably referring to when they said "dot gain" is the optical bump that occurs when dots start to touch. With a simple Euclidean dot (round/square/round) that bump occurse at the 50% tone and in press work can appear like a dark line at the 50% tone that might appear to be dot gain.
Elliptical dots split that optical bump into two - half at about 40% when the dots first link up in one direction (first axis) and the other half at about 60% when the second axis of the dots start to touch. This moderates the appearance of the optical bump.
But the bumps are still in the important tone areas. And the directional nature of the dots in an elliptical screen can cause other problems.
Round dots bury the optical bump in the shadows at the 75% tone so it's not visible.
best, gordo
[snip] The reading that I have done has explained that elliptical is used mostly for screen printing and other print processes with heavy dot gain.
That makes no sense. One counters dot gain with a compensating tone curve - the dot shape has no effect - unless they are referring to the optical bump that happens when dots first touch (see my other post).
175 lpi round dot. Square dots are very rarely used anymore.
Can't you fix the 1/4 tones with a tone reproduction curve applied to the plate?
best, gordo
Thanks Gordo for the information. I am using Curve2 Software to create our press curves and haven't done any adjusting of the curves coming out of Curve2(which I believe is needed to match a proof made with the GRACol data.) My predecessor always wanted to adjust the proof, but in doing so we always moved further away from the GRACol standard, which makes sense. I have always contended that the difference in line screen may be the reason we do not match the GRACol proof(and that plate curve adjustment is needed), and that the use of the elliptical dot shape is making our job harder. Thanks again for your insight, always much appreciated.
Best regards,
Todd
I really can't see how the use of the elliptical dot shape is making your job harder. The difference in line screen (200 lpi vs 175 lpi) would result in a very slight difference in dot gain in your 1/4 tones. Have you checked the optical brightening agent content difference between your press paper and your proofing paper? That can make a difference in the appearance in you 1/4 tones.
best, gordo
Round is Sound, Elliptical is Cryptical ( that is what we used to say, but I have no idea as to why we said that )
I am with Gordon on the above.
Elliptical - is not your problem. . .
elliptical dot shape is best for "skintones"
Since the 60's when someone came up with the elliptical dots, it has smoothed out the middle tones in practically all types of printing. . . does things that are hard to do any other way! I thought I was an expert when I bought my first 'elliptical screen for the old camera method of halftones!! Telling my age too -- been a LOT of changes since those days. . .
Elliptical dots were developed reduce the visibility of the optical bump that occurs when dots start to touch at the 50% tone. In a camera back glass screen, or film screen, dots that start out round in the highlights become squares at 50%. When the corners of the dots join there is a visible bump in tone that shows up as a dark line. This type of screen is called a Euclidean halftone dot. Elliptical dots break that bump into two lesser tone jumps - one at 40% and the other at 60%. But the tone bumps are still in the important midtones. Also, if you're using a low lpi screen, 133 lpi or less, the elliptical dots chain and form visible lines in the tones from 40%-60% - not good for skin tones. Plus, because elliptcal dots are directional they can magnify press issues like slur and doubling.
The best AM/XM halftone dot shape in a CtP environment is round (i.e. Non-Euclidean). It puts the optical bump in the shadows at 75% tone. It is non-directional and the dot shape is the same at every screen angle.
best (greybeard) gordo
I also asked the question: Why 200 lpi? We just had too much trouble printing with 200 lpi Square dot specially on matching previously printed samples. We did a couple of tests with square, round and eliptical 175 lpi and settled on 175 eliptical. None of our customers even noticed.
I assume that you don't actually mean "Square dot" but you mean Euclidean?
The ability to "match" 200 lpi to 175 lpi presswork has nothing to do with whether the dot shape is Euclidean, Square, Round, or Elliptical. It has to do with your process control and the ability to implement tone reproduction curves to your platesetter.
Improving your process should not depend on whether your customers notice the change or not.
best gordo
Thanks for the reply gordo. We found out the hard way that what you said is true. We have implimented a couple of checks to control these processes.
We used Eliptical dots 175 LPI in the CTP. We changed the dots to round some time before and we purchased a new CTP at the same time. Customers now say that the job is sharper because of new CTP though we give plates in both CTPs.
The 200LS was decided on before my arrival(16+ years ago.) The thought process was that it made our company stand out as a high quality and was used as a selling point. My thought process is that with standards becoming more important in the printing industry, why wouldn't you want to print in the same manner as the data that you are trying to emulate? With the advent of stochastic, I really don't think 200LS is that much of a selling point anymore.
Best regards,
Todd
The thing is that, with CtP and digital proofing, printshops do not have to restrict themselves to having one print condition.
Would you shop in a clothing store that only carried blue plaid shirts?
If you define "quality" as meeting customer expectations (as W Edwards Deming does) then you can offer industry standard printing for those jobs that need to align with the standard, shop specific printing to differentiate your presswork, and even customer defined presswork if that is what's appropriate.
IMHO, you'll have a much better chance of success if you align your presswork to your customer's job needs rather than an arbitrary industry specification.
best, gordo
