Looking for some help on our epson 9600 printer. We use the 9600 to print press-proofs. We manually load sheets of paper. The size of the sheet we load depends on what cylinder size is being used on the forms press. When we load the large sheets (23x31) the printer will print the 1st side just fine. But when you turn the sheet over, the printer will simply run the sheet thru without printing the second side. Only after you release the paper and send it thru again, will it print the second side. This gets frustrating when you have to do multiple in a row. I have checked the properties of the hotfolders and I can't find the error. The smaller sheets print both sides just fine, one right after another. Any help with this issue is greatly appreciated.
Todd @ ARS
Todd @ ARS
