Epson 9800 Low-Res proofing
minder
Hello, wondering someone out there is able to help with solution.
My workflow is Heidelberg Prinect Singa Station 16 with the latest MetaDimension 16 RIP.
I want to set up my Epson 9800 as a low Res proofer. I plan on using 32 x 42 60lb-70lb uncoated sheets . How do I go abouts setting up the printer to print centered on my sheets so i can do sheet-work and work & turn proofs to back up.
Do i change the setting at the printer on at the RIP
Thank you
