Two questions regarding the Epson WT7900:
Looking at the Epson site, they only have a MS Win driver available? So what if this is being installed in a Mac OS setting?
More importantly, when it comes to MS Windows XP SP2, I am having problems with the available Epson Communication Driver 1.2 for the WT7900. When it is installed, getting properties on the driver it says that "You can't print with this driver". The Test Print page does not work. I believe that the EpsonNet utility has created the correct printer port, as it looks the same as for our Epson 9900 which does work.
Any ideas on getting the WT7900 to work under MS Windows XP SP2? There is very little HD space left of C drive, so I am wary of updating to SP3, however I will try to do so if required.
EDIT: one can't simply use the 7900 driver, it must be the WT7900 driver.
Thanks in advance,
Thanks in advance,
