T TLawrence Well-known member Oct 3, 2015 #1 I have been getting this code alot. Anyone know? Heidelberg tech has no idea, thinks im crazy.
T TLawrence Well-known member Oct 27, 2015 #5 Yeah i know. Like I said the tech doesnt know either. But it does show up. Just wish I could figure out what it meant.
S STW100 Active member Dec 2, 2015 #9 15-08 is a braking issue! Meaning the press is not stopping quite perfect for the software. Poss need to tighten the belts. If you are rec other strang 15-0? codes, check the roll pin in the main dr gear at the impression cylinder! Stan ipsqm46.com
