impodave
We've recently attempted to switch from Nexus Pageflow to a Nexus PDF workflow. We use Dynastrip 5.3.1 for imposition to plate and proofing. We have encountered a number of issues that neither Esko or Dynagram are prepared to solve. I don't have much experience with design programs or Neo, so be easy on me...
1)If the job is all CMYK, we're good to go. If It is spot colors, I'm in addition getting CMYK showing up when sending to plate. The design people insist that the only colors in the document are the proper colors... Esko suggests that the files may be incorrect.
2) The output controls that I am used to having in Dynastrip have been compromised using JDF PDF. I cant send one side of a sheet without the other side going also. The only way to prevent this is to use the prevent output function(black box) under sheet. The front or back checkboxes are useless. I can't send one color without the others going also. The only method I've come up with is to place a hold on the copy file module in the workflow...
3) The custom file name that Ive created in Dynastrip ( Not the text tag on the plate) will not not appear in the queues in either output device. I spent half a Saturday playing with the naming functions in the workflow just to give the platemaker a decent way to recognize exactly what job or sheet he was making...
Any comments or suggestions would be appreciated....
