Hi Stephen Marsh,
Right now iam checking my image's acrobat and making correction in photoshop in selected area it works good but takes time also. I work for packaging products an they require 280% as ink limit
regarding profile convertion i tried it but color changes drastically i will try new profile suggested
Juliane
Juliane, as I was alluding in my reply to Lukas & Gordo, I would not re-separate the entire file if going down the "standard" CMYK > PCS (or RGB) > CMYK route. Unless done well, there are too many problems with re-separating the entire file when it is only the shadows that are an issue.
I would work in a dupe, convert that to another profile, then blend in the new conversion as a layer over the top of the original conversion. The new layer would be masked, so that only the neutral shadows from the re-separation were being added. The majority of the original separation would be used, one is just replacing the shadows and close tonal transitions (no point throwing the baby out with the bathwater). The CMYK destination profile would of course need a 280% TIL/TAC/TIC value.
If there were areas of deep hue/colour that were over the total ink limit, like a deep blue, then I would make selective edits to such colours as needed.
If you have the budget, then getting into device link or other image ink editing software would be more productive and would provide better results. Even with a lesser budget, a consultant can build and licence you a device link profile, which would bring down the costs compared to buying DVLP software outright (enter Matt Beals). You would need Photoshop CS4 or a RIP capable of using CMYK to CMYK device link profiles to directly convert CMYK to CMYK (bypassing the standard ICC profile PCS).
I previously mentioned a less refined, but free total ink limit action. This action can be found here:
http://www.curvemeister.com/downloads/cmyk_tac/index.htm
