In your first post you wrote this:
"I get a 2cm stip pf ink at the top of the plate, before adjustments it was 2mm".
Is that 2cm really what you meant? Or is that a typo, as in the case of "stip pf"???
The reason I asked about your stripes in the middle of the plate is that your 2cm indicates that the ink rollers are hanging down pretty low in the cylinder gap. So if your ink roller stripe in the middle of the plate are 2.5 mm, your rollers may be too hard.
I recommend that you get an experienced press operator or service man to help you on site. I suspect that the information you are giving us on this forum may not be reliable due to either poor observations, or poor writing skill. No offense intended.
Al
