D
Deleted member 16349
Guest
Hi Erik,
You are correct that CMY density has no direct relationship and would be a poor way to go for determining ideal gray. However, the "triplet" values are not density values, but patch color percentages. Think of it this way. 50C, 40MY is the optimal value to yield the neutral gray (according to G7), but if that patch doesn't actually measure neutral (in CIELab, not density) from your press/printer, perhaps a 50C, 38M, 43Y does. The GrayFinder target has patches of differing CMY percentages to help determine the optimal compensation toward gray.
The GrayFinder method makes more sense than the manual method explained in the webcast. You go right to the patch that gives the best result to use as the data for compensation. I guess it is more applicable to the automated method that Don also referred to.
