head wipers for UV ink
Did you find a solution yet? We run an Arizona 660 flatbed with UV. Are you running something similar?
Contact Lisa Fine at Joules Angstrom, Phone 708-423-8964. She is a wizard in everything UV and will give you the proper guidance.
D
Shouldn't be using anything other than what Oce recommend In their Bulletins. you clean the head with a wet swab dipped in isopropyl, purge the head then use the suction thing to pull off the excess ink. 3 years with a 480 and no nozzle outs. No head replacements.
