Heidelberg Ink Roller Setting
Davis.zhou
I got a diagram of Heidelberg ink roller setting. The ink strip of the roller #13, 2, 1, 14 should all at 4mm.
However, I found that there is an other diagram which stick on the frame of press showing the ink strip of these four ink roller is 2, 3, 4, 4. mm (for ink roller #13, 2, 1 & 14).
Which one should correct or both setting are correct but for same model of Heidelberg CD102 manufactured in different year?
I use these and have great results!!
Thanks for your information. From your attachment, there is another set of ink roller strip setting:CD 102 5mm 4mm 3mm 3mm.
Why there are some many different ink roller setting for a same model.
using different setup parameter will cause any problem?
Thanks again.
