D
Deleted member 16349
Guest
Erik,
This sub-topic is getting "Silly" enough is enough - the end.
Regards, Alois
Agreed. No more. Back to the original problem.
Erik,
Regards, Alois
Hoping someone can help here, as of 2 days ago we have been printing fine on this press but now the second unit seems to be flooding the plate with 2 much water. Here is what we have done so far: We have replace and reset all the rollers in the water unit, we also have a second parts machine where we took the water unit and put it in the newer machine and it did the same thing. We replace the air pistons thinking they were not put the rollers in proper position and this didn't change anything. We have tried having just a.5mm strip on the water form to the plate and it still had too much water. We have pulled all rollers out and cleaned with pumas and then did a water/vinegar wash still same problem. We are using the same fountain solution in the first unit and it is working fine so we know that is not it. We even swapped the inks and that didn't change anything.
We are at a complete lose and so is our tech, if anyone has any other suggestions beside gasoline and a match it would be very appreciated.
