Hello people,
I'm looking for a solution in printing PDF files from multiple workstations to a printer. I figured the best way is to setup the printer on one workstation, also setup a utility which will monitor defined folders and print incoming pdfs automaticaly. The users would only need to copy their files in the watched folders. The question is which utility. Do you have any suggestions? I came across PDF Multi Print and HotFolder printer which I will test but I would appreciate any other suggestions.
thank you in advance
