Gregg
I'm most likely getting an additional workstation, and it will be the latest generation iMac. This would be my first time using a LCD flat display in a professional environment, and I'm curious about the results I can expect.
I've had a trusty Sony CRT w/hood for years, which I calibrate every 4 weeks (using Eye-One). I've always been happy with it, I can clearly see a 1% or 2% dot, whereas, on my designers flat displays, that same area looks pure white. Granted those are more lower-end monitors.
Is there a preferred Gamma for the newest iMac monitors, or anything else I should take into consideration?
