I have several ink guys in our pressroom that all seem to have a different philosophy on this topic and I'm hoping to standardize the way the balance is achieved. The most "productive" method so far seems to be to balance everything according to the piling on the blankets. In other words, get the balance and then adjust the water to get the longest stretch without washing the blankets (btw, this is a MAN Lithoman 4 100k/hr doublewide). I appreciate any input from those that work with similar equipment.
There is NO SINGLE approach to setting ink/water balance. Printing is a very complicated science that needs to be adapted to each set of circumstances (i.e. press, materials, product).
Very interesting read. Quite amazing all of the different view points.
I agree with you in prinicple, however, not always the case.
For example, some very fine grained plates will look very shiny but still scum. The appearance is decieving. In this case, plate shine is not the ONLY way of setting ink water balance.
Also, piling is very much affected by dampening. In an intergrated dampening system, adding more water to your emulsion will help reduce reverse image piling, improve blanket 'lubrication' (for lack of a better term), keep temperatures lower, and, on the subject of tack, reduces the tack.
After quite a bit of observation, experimentation, etc. I have found that adjusting waters in one unit can help reduce piling in suceeding units (all to do with tack).
On the blanket piling scenario I will agree that dampening rate does reduce blanket piling in the non image area but I totally disagreee that more water "reduces ink tack". Fountain solution chemistry itself does affect ink tack, but not dampening rate. Adding water actually increases ink tack by bodying it up on the plate. How do you reduce picking?.....lower the water or reduce the ink tack(by adding oil). At the point that ink actually has lost tack form water, it's been broken down.
What are some examples of commercially available positive ink feed systems?
Al
The company I work for sent some people from an insert plant to the plant I work in for training (long story). I worked with a supervisor and lead operator. They were telling me about the "closed loop color" that was installed on one of the Goss presses they work on. Apparently they didn't know the difference between the separate Goss Digirail and closed loop control, they just referred to the whole thing as "closed loop color". I had to show them 4 presses with traditional closed loop color setups before they understood the difference. Anyway point being there is some installations being made with Digirail being controlled by closed loop. I'm not sure how Goss markets Digirail itself tho.One of the Goss mottos was, "Set and Forget". Basically they are saying that once set, there is no reason to adjust. There would also be no need to have a closed loop colour control system on a press with a DigiRail system.
Eric,
That was slightly over my head but I can't help but get the feeling you come from a sheetfed background. Your comment about "50 impressions" is what makes me say this. From my experience, nothing happens on a web press in 50 impressions. If you were to mount a plate with less coverage and start the press with the ink ball turned off, you still wouldn't run enough ink out of the roller train to bring the density down. I've never worked in sheetfed but I did interview once. I recall the guy telling me the biggest run they get is 5000 sheets. Honestly if I can makeready a commercial webpress in 5000 impressions I did pretty good that day.
I'm no engineer but I work with older GMI Colorquicks on Harris presses with swinging ductors and Man Rolands and Goss presses with newer Quadtechs and continuous ink feeds so I'm pretty familiar with their operation. Personally I can see closed loop color working fine with Digirail on a webpress. For one it you have the head of the closed loop color that scans back and forth checking the density, it scans from operator to gear then moves back to the operator and scans again and that's after it even finds the colorbar which is at least 400-500 impressions. I've never counted but I can't see one scan happening in less than 100 impressions moving at only 700fpm. (the slowest I'll ever makeready a decent webpress). Ink key movements are always relative to the density it scans, but it never moves any single key more than 5% at a time.
That's just to give you an idea of what I look at everyday. The only thing expected to move fast is the paper through the press. The time it takes the micrometric to scrape the excess ink off the ink ball is peanuts compared to the time it takes for the roller train to exhaust itself to the web. On that note an inkball on a press with a continuous ink feed actually tends to run pretty fast anyway.Where press with a swinging ink ductor never actually stops recieving ink from a keyzone that is at it's lowest point you tend to nurse the ink ball speed to keep the ink as low as possible in a low/no coverage zone. A continuous feed press can always have the keys ink film low enough to never touch the ink ball, so you can have that ink ball run much faster. AFAIK they don't even install Digirail on ductor fed systems. The guys I talked to told me that Goss actually retrofitted the press with micrometrics when they installed the Digirail.
In my experience, closed loop color is best used to maintain densities and help achieve a final result. On an older Harris with a GMI, it serves practically no purpose in makereadys. It's too slow to find a color bar and too slow at making corrections. My procedure on these presses is to adjust the presets, start the press, balance the water and shut it off. I look at it, make ink moves start it back up and begin running if it's up to color. At that point I set the GMI into closed loop to fine tune while I'm already running good copy. On a Man Roland which has the best fully segmented, deep pocket ink fountains I've ever seen I turn the Quadtech on from the start but I never expect it to bring the densities in by itself during a makeready. Ill watch the densities on the screen and make the big moves on the ink keys myself for a minute then shut the press down. Make the rest of the colormoves, start the press and begin running with it still in closed loop. In this environment I can easily see Digirail working fine the way it is. Wasteful? Absolutely, but it's what is expected in web printing
Thanks for all the comments from your experience. It is helpful as a reference.
I am not talking about only sheetfed. My major practical experience is with web presses although the science I have developed applies to both.
I can understand why this might be hard to believe but I still say that getting to colour in 50 impressions is still a practical target under the conditions I stated. It requires changes but if people accept long makereadies as being normal, that creates a huge problem just trying to get past that phycological barrier.
Think of a combination lock. If you know the combination, you can open it right away. If you don't know the combination it takes a lot longer and seems very difficult. Same problem for both situations but solving it depends of specific knowledge. That is the kind of knowledge I have developed related to the density control problem. It is very specific to that problem. There is a need for some press manufacturer to take it to the next level.
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
