I would think that with a clever enough engineer and sparky it would be doable.
Obviously you're going to have to look into the voltage requirement of the lamps and upgrade wiring etc to suit, and as Cornishpastythighs suggests be very aware of cooling requirements as a fire could easily result given the high temp they run at.
I'd also check with a Heidelberg specialist with regards to wether or not the mechanical parts in that area would require heat shielding and possibly if another oil would be required to cope with higher temperatures.
Simply put, I don't think it would be cheap to do, but trading the press in would certainly be more expensive and possibly involve downtime etc... I like the fact that someone would have a go at something like this rather than just trade it: to my mind its the kind of attitude that deserves some respect
On modifying presses for jobs outside of their original intentions, we used to run a job on some Akiyamas that was up to a million+ runs then perforated on another single col A2. One of the Aki's (628) was fitted with a solid bar that mounted up to 16 GTO style perfing arms/wheels. The common impression cylinder between units 5/6 was fitted with custom jackets, and there you go: a machine capable of printing at a comfortable 10-12,000sph and 16 up perfs at the same time. Whilst I'm certain that there would have been better machines available with perforating as an option, this was a cheap, well thought out modification that saved us mountains of time
