Nokturnal1
Hi all,
This is my first post on here. Im looking to see if anyone knows how to edit the Javascript for Illustrator CS4? Adobe already has a script in Illustrator called 'SaveDocsAsPDF.jsx'. I want to be able to tweak this script so I can edit the PDF Save Options to do things like add trim marks and bleed, since this script clips the bleed at the trim box. When I open the script, it gives some info like:
// See PDFSaveOptions in the JavaScript Reference for available options
// Set the options you want below:
// For example, uncomment to set the compatibility of the generated pdf to Acrobat 7 (PDF 1.6)
// options.compatibility = PDFCompatibility.ACROBAT7;
But they fail to mention where this is 'JavaScript Reference' is so I have no idea where to find the script options. Anyone out there have any idea? I am not a code person, but I do have the awareness of how to edit them.
