Lines on Silvermaster plate
Hi I'm running a DPX with Agafa Setmaster plates (510x400) and I'm getting a constant line running from top to bottom(400) about 170mm from the tail end. This line sometime prints and is now a problem. Any ideas out there on a remedy?
Vernon
Clean processor. We saw this on an older processor. After a long period of time silver deposits harden on the bottom bypass rollers and leave this mark on the plates. If your stabilizer unit is the same as your developer unit you can try swapping them after a cleaning but I am pretty sure they are different. I believe the exits are different on each unit. Try taking an SOS pad and scrub the lower rollers in the developer unit then rinse them real well
I took your advice and gave them a good scrubbing with trepidation. The plates are running
lovely and clean now. Occasionally there's a line in that same place but I can easily put up with that - sorry for late reply.
