Hello ,
I have the following problem- on Lotem 800V the drum speed decelerate from time to time. From 900rpm, it slows to 570rpm for example. The speed decelerates and if the Lotem "decides" increases the drum speed to the normal value. I have checked the wall voltage-it is OK, the diagnostics does not show any problems. I have checked the fuses and they are OK. Everything seems to be OK, but from time to time the drum decelerates.
It is interesting that the syncronization between the carriage motor and the drum motor remains, because if the deceleration starts when the plate is exposed on 90%, there are no artefacts on the plate- skew image or something like that.
I appreciate any suggestions.
