Just recently the motor that feeds the spraybar in the central washoff section has been running constantly. Short of switching the unit off after every plate run, I'm at a loss as to where the issue is. There doesn't seem to be any contactors in the system that I can see that might be stuck in the On position.
I've run the AndroDiags monitoring program and even setting the motor Lock to O it won't stop running. I have to turn power off at the main switch as even setting the unit to Inactive doesn't turn the motor off.
Any ideas welcome.
Any ideas welcome.
