NDc barcode issues
amybest222
We do alot of pharmacutical work and we've created these NDC barcodes using barcode producer 6.6.1
For some reason
1 the numbers i enter are generating an extra zero at the end (not the code the client wants to scan).. the add on is automatically generated and is correct
2 the numbers are generating an extra zero and the add on is incorrect the client is suppying a 10 digit number including the add on
FYI NDC barcodes
FYI NDC barcodes
The support at Barcode Producer were nice enough to get back to me:
You can generate the correct barcode with Barcode Producer by entering "3" followed by the NDC (with dashes) into the content field. It is not necessary to enter the check digit as it will be computed automatically. As the dashes in NDC values have a special meaning, I would also recommend clicking the Advanced button and turning on the "Human Readable Text Under Guard Bars" option. This option allows the NDC value to be shown with the dashes.
For some reason
how to make sure it is a correct barcode generated?
