Let's see. I would say the biggest advantage for us is the fact they will essentially bleed off 3 sides of the sheet now. That is the one thing that immediately stands out since it makes my life easier on a daily basis.So what advantages have you seen on the 7500 vs the 7200?
The ix1700 came out but is to rich for my bloodSo much for inkjets dropping in price.
Japan and Fiery are working on some updated patches that should be released soon (hopefully).I have found a workaround for the VD issue. If you "process and hold" the job then print it doesn't seem to crash. I suspect there is some type of communication issue. I also notice the blue status light will frequently stay on solid instead of flashing for no rhyme or reason.
When our service guys installed it they seemed just as surprised about the bleed ability. We regularly run 12.5" x 19" stocks and just barely have enough room for cut marks. Our cutter was ecstatic to see this one giving her cut marks on every job.Interesting about the PTR no longer being used, does the belt assembly have to be changed as well due to lines from different size stocks?
If you get a chance to do a video about the bleed I would be interested in seeing that, I have not seen that mentioned before.
The marks from different size paper are usually on the fuser roller, but yes you have to replace this belt, but it seems much more resistant to damage than the old roller. This is just like a smaller version of the belt that transfers the toner. They went to a fair amount of trouble moving the drive assembly for it to the operator's side. I am optimistic. Still runs envelopes just like the old version with the refolding of the flap. Registration is every bit as good and it seems to run envelopes faster through the bypass tray. I have been told it also is faster with mixed media, but haven't tested it out yet.
Yes it is.Is the belt part of the TCRU program, is it something you can change?
I ran a letterhead the other day and it had a solid that bled on 3 sides. No issues with that. Only the lead edge has a margin.I had to reread that, so just cut marks are bleeding off the page. I was wondering how a full image bleeding off the edge would do, I would think it would fill up your waste toner bottle really quickly and not sure how all that excess toner flying around would be handled.
I got a call today saying they have a firmware update for the printer, NOT the Fiery, which is supposed to fix the error. They are supposed to come up and install it tomorrow. I will let everyone know how that goes.Thanks for the heads up, I might be better off waiting for an affordable cutsheet inkjet to come out. I am happy with my 7200 currently.
Hehehehe....After about a month of tearing my hair out of frustration and multiple attempts to reload the RIP hours our technician said he would have to escalate things. I contacted our salesman at that point and told him what was going on, apparently, he had no idea there were issues. Two weeks ago the tech came back with a RIP reload that had something like 50 patches, some of which were not public yet. He imaged that onto the RIP and boom everything was working without EC errors. We have put 600,000 12.5x19 clicks on it in the past 9 weeks. It still has some small glitches about once a week, but a reset fixes. At this point I really love it. Both our 72xx machines would run slowly on certain files that we could never figure out. This machine doesn't do that and seems to have fewer jams. It also runs 20pt plastic better. Our only remaining issue is Fiery Color Profiler Suite always crashes at the end of profiling leaving profiles partially installed. We are waiting on a resolution to that, but it isn't anything more than an annoyance.Any updates on how the 7500 has been running?
how do you like the 7500?We have a 7500 coming to replace our 7200. So I will have the 7500 next to our 7210X.
If anything, it is a little bit worse at refolding.Glad to hear they fixed the issues
Have you tried running #10 envelopes through it lately? Curious to see how that is going or if it still has the refold like the 7200.
The only complaint is the software bugs. Still not totally resolved. They have it working, but still has bugs that annoy you and require resets every so often. The last engine software update actually made things worse. At this point, I have learned most of the quirks and shutting the machine down each night and starting it fresh in the morning seems to be the best course of action.how do you like the 7500?
