Anyone able to critique the advantages of Pitstop Extreme over Pitstop Professional?
How does Pitstop compare with OneVision's Speedflow or Asura product?
Speedflow Edit and Asura Solvero are the respective PDF-Editors from Onevision.
As I have only worked with SF Edit so far, I can only comment on that. But Solvero should be no different, as it only outputs some more formats where Edit is confined to PDF as output.
SF Edit can do everything that PitStop Extreme can do (and some things more), but does not have a trapping as an addon-feature. SF Edit has another benefit: it will write the complete PDF using its own engine, which produces quite "trouble-free" PDFs.
For example, I have several PDFs that the latest Adobe PDF Print Engine does not rip correctly; after I just open and save (without changing anything) in SF Edit, APPE will rip them correctly.
SF Edit does not have something sophisticated like PitStop's Action Lists or Profiles, but rather rudemantary search/change features.
I find changing and editing in a PDF using SF Edit much easier and faster than using PitStop Extreme. It is a bit like using Illustrator to edit PDFs, but without Illustrator's risks
PitStop Extreme's look and feel and how you use it just feels really dated and cumbersome in comparison.
Both are capable PDF editors, of course.
You can get a demoversion of both and decide for yourself, though.
I have to correct you on this. PitStop Extreme doesn't have a trapping module as add-on. For this feature I kindly direct you to the EskoArtwork Neo product:SF Edit can do everything that PitStop Extreme can do (and some things more), but does not have a trapping as an addon-feature.
PitStop Extreme does not use the Adobe PDF Print Engine, but the Enfocus PDF Library. If it does correct the mistakes a test will provide that result.SF Edit has another benefit: it will write the complete PDF using its own engine, which produces quite "trouble-free" PDFs.
I can't talk about SF Edit, but the feeling you're talking is also what you have with PitStop Exteme. It is a PDF editor, so indeed no risks like illustrator.I find changing and editing in a PDF using SF Edit much easier and faster than using PitStop Extreme. It is a bit like using Illustrator to edit PDFs, but without Illustrator's risks
What would you like to see different related to UI?PitStop Extreme's look and feel and how you use it just feels really dated and cumbersome in comparison.
I have to say, I'm running the demo for Extreme and I really like this app. I love the standalone aspect, it's very fast, capable of all the edits I'm looking for - including a real text editor if needed. Good color tools, and can work with gradients no problem. Here's a look at some of the windows and info/options in Extreme.
If a picture in a PDF is too dark or too flat, is there a way to lighten or add contrast to an image ?
I think something like Levels or Curves would be sweet !
Michael,
There is a very close relationship between PitStop Extreme and your image editor of choice. In the PEX preferences you link the image editor you want to use.
Then you select the image which is too dark and double click the preview on the fill paint window. The image will open automatically in the image editor...
Just a fast way of doing some last minute editing...
Cheers,
Bert
Hi Bert - I can do THAT in off the shelf Acrobat using the TouchUp tool
what I was hoping to hear was that PitStop Extreme had some image editing tools - but I heard from Enfocus that it does not.
What about the PDFlib 9.0 font issue? How would Pitstop extreeme display the fonts, like Acrobat 8 or like acrobat 9 (refering to the Null character that you get when placing a PDFlib 8 in a CS4 document and exporting to a PDF other than PDF/X-4:2008).
Can this problem be detected / fixed ? Preferably by a dropfolder?
@ abc
Speedflow Edit - as far as i can find - "pricing is based on configuration and individual requirements" - the only reference to the price I could find is £6300. Less hefty than PitStop Extreme at £9100 - but that I read in July 2006 !
