Polar 90 cutting problem
Dieudos123
Hi everybody,
Please anyone can help me with POLAR 90?
It has the following problem:
When I try to cut sometimes it cut and sometimes it does not or the knife
remain down.I have changed hydraulic oil but no change.What can cause this?
Thanks in advance.
Buntpapier
Hi Dieudost123
To help I need to know which type of machine you have.
On the name plate you can find the machine type and the number.
Do you an electrical drawing?
Buntpapier
Dieudos123
Hi Buntpapier,
Thank you for your reply.
The machine is:
POLAR 90 MOHR
Model:90 CF
Masch Nr:4511280
220V /17.3A /50HZ
If possible I need Electrical diagram and hydraulic diagram.
Dieudos123
Hi Quadraernie,
I thank you for the reply.
I have contacted you through your E-mail.
Please check your E-mail.
Buntpapier
Hi Dieudos123
To fix this problem you need somebody who knows Polar-Cutters. Your problem is an electrical problem. Mostly the board 8 or the gearbox limit switches are broken. But instead of changing expensive parts I would suggest that somebody checks the machine first.
The machine was delivered with the following drawings:
90CE-1101c
90CE-1102c
90CE-1103c
90CE-1104c
SE-0209/1
To send the drawing I need a Mail-address
Best regards
Buntpapier
Yasi
Hi Buntpapier,
Could you please send me a copy of the wiring diagrams for the Polar 90 CE as well.
I am in desperate need.
Thank you.
