Regards, Alois, see PDFs
" Where would we be without a little frivolity "
**** Had a problem uploading 1 more PDF - a Important one !!!!!!!
I suppose that in the interest of a fair test we need to further define overdampening. The operating window for correct dampening at times can be pretty large.
Eric are we to understand that in your test we should not be able to overdamp the image under any of these variables? For the purpose of this test are we to overdamp as we see fit?
To me there is slightly overdamped and then there is overdampened where the plate is so wet that its casting a glare in the pressroom and blinding people as they pass. Dont laugh ive seen pressman run their plates THAT wet. My understanding of your technology is to make things a bit more user friendly for the press crew. Would your technology allow for a pressman that always runs his plate soaking wet?
Gentlemen,
The emulsification curve of the Ink/Dampening solution can be used to predict press performance.
Regards, Alois
I don't understand this graph either.
This is why we deveopled a test called 'Ltiho-Dyna-test to predict ink/fount perfromance of press. This is nothing but a Ryobi press and we can run variuos inks and fountain solutions to check out the scum point and wash out point of inks.
The ink that cleans up at lower water settings and will not wash ou at higher settings will impart wider lattitude and easy control in the pressroom on wider, faster presses.
George John
Hello fellow Lithographers and Mr. Al Ferrari
The answer you seek lies within ............................................. PDF
Regards, Alois
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
