Proofing Best Practices
With the adoption of digital proofs, laser proofs, and CTP, many companies have circumvented some fundamental procedures; contributing to significant spoilage costs. You can significantly reduce spoilage by implementing better procedures for producing proofs and approving production makereadies.
The following procedures will help to ensure that the final product is technically correct prior to running a job. Once the job is printed it is too late! The idea is to catch the mistakes before they get further down the production process and increase in spoilage cost. The little time and costs these proactive procedures may add to the production process is considerably justifiable by the savings in spoilage, improved quality, and improved customer satisfaction.
Imposition Proofs - Prior to imaging plates, digital imposition proofs should be made of each signature to verify the position, layout, pagination, marks, trims, bleeds, and content; prior to plating or press. Imposition proofs are typically the size of the press plate and can be a digital Dylux, Sherpa, Spinjet, or HP Inkjet proof.
Folded Dummy - Optionally, a second set of imposition proofs can be made, gathered, and trimmed in the book format. The "folded dummy" is an important aid to ensure the job is technically correct for cutting, folding, and binding; prior to plating or press.
Press Rule-up Sheet - All jobs and signatures should have a rule-up press sheet on which rules have been drawn to show trim, final size, spine, perforations, folding, etc. The rule-up sheet is verified against the Imposition Proof made in prepress. This is a double check of the mechanical layout to verify that the signature will trim and bind correctly, that the pages are in the correct order, and that there is enough bleed. Mechanical correctness must be confirmed at the press during the makeready. Once the operator is confident that the signature is technically and visually correct, the pressroom supervisor should approve the job for running by signing the press rule-up sheet. This is where the term “Signature” originated.
Hope this helps.
Craig L Press, Printing Industry Business Consultant
Profectus Printing Industry Business Consultants specializing in best practices, lean, and information technology
