I am tasked with establishing a common colour appearance for 5 presses. As each press is added we start with a G7 press run. This is establishes the presses starting point. We have CTP curves for each press. I'm very familiar with the G7 process and NPDC's. I am fortunate that we only have 2 medias, this is an offset packaging environment. What I am looking for is a process to monitor and update the curves over time. I don't have data collection at the press as all the presses are density only closed loop and I only have a limited amount of real estate for colour bars. Usually I only get a 25, 50, 75, 100. One thing that I have learned is I can't use one or two press runs to change the curves. It takes a bunch to see a trend. There's no way I can put the P2P back on press.
This industry needs a SIMPLE piece of software that can take the 25, 50, 75 CMYK individually and a set of CMY's to determine grey balance. From these measurements one can average and smooth the data and recommend curves adjustments for TVI or NPDC. I don't want a cloud solution, I want to local. It needs to independent of all the big players. It should show trending and TVI spread for each of the colours from the data received. Does this exist?
Why do we spend so much time calibrating the most stable piece of equipment, the inkjet but not press calibration, it is so important and is so often neglected. Just my 3 cents.
