Problem of density
Mohamed,
Exactly what type of density issue are you having. Is your Dmax to low? Are your screens off? There are many factors that can effect you density. Need to know what you are experiencing.
STSTech
Yes the Dmax is low. I try to change the resolution from 2540 to 4000 and the puissance lazer to 350 but the result is also bad. we
Mohamed,
Before you start changing settings, you need to check a few things. Make sure your optics are clean on the imagesetter. Next, take a piece of film and expose it to the daylight and process that piece of film in your film processor. Your expose film should have a Dmax of 5.6 to 5.8 .
If the Dmax is low, check your film processor settings, check your chemistry, and try a different roll film.
STSTech
me too. I think same Mohamed, you should clean mirror , new setting laser power and replace new developer solution.If life cycle of laser to end you replace new laser.
Goodluck.
