The paper catalog in Command Workstation on the C900s is probably one of the most useful features that I use on a regular basis. With that said, I've run into a glitch that prevents me from changing settings in certain stocks that I built in. Also, it will not allow me to delete the stocks. It gives me an error that says "failed to delete item". I've also tried restoring the factory defaults which is suppose to delete the items I built in, but it doesn't.
I was wondering if anyone has come across this problem. It is definitely a C900s issue because I have tried changing or deleting items on different computers. The only solution I have found is to ask the tech to reinstall the Fiery on the C900s. That doesn't fix the problem permanently.
Any help is appreciated and if this is a double post, my apologies.
