mglouis
Hello.
We run violet plates for sheetfed, LPNV2, that are rated for 1-99% up to 200 LPI and maintain/confirm plate linearization, meaning file value = plate value, using a ccdot which has a resolution of .5-99.5 in 1/2 % increments is rated to be accurate +/- 1%.
Dot area across a plate holds within a 2% range as does dot area across multple plates.
CtP curves are a result of G7 + Rampage's 25 fulcrom curve requirement. 1% file value per NPDC should plate as 0.9 -1.3%. 3% file value @ 2.3 -2.9%
Highlight control, especially in regards to raster 4cp gradients that fall out to 0%, has proved especially challenging for us. An example gradient may go something like this: [c 2.35 m 2.35 y 2.35 k 2.35 (tac 9.41)] down to [c 1.18 m1.18 y1.18 k1.57 (TAC 5.10)] down to [c 0.39 m0.39 y 0.39 k0.78 (TAC 1.96) down to [0,0,0,0]. "Moderate" variation in darker tones goes undetected for the most part. In highlights, we can all agree loss of process control in this range is unsightly.
At either ctp or press or both, tone reproduction in the highlights falls apart. It does not seem unreasonable for a designer to request a gradient that zeros out smoothly but I am having difficulty finding a process that enables this to happen reliable. Pleasing results are a crap shoot.
Can anyone suggest process improvements, equipment modifications, or tips and tricks, for accurately reproducing file values in extreme highlights? If you can manage excellent highlight control, how do you do it?
Thanks,
Matt Louis
Thanks,
Matt Louis
