Process-free Plates
prepressdork
I am hoping to get a new plate reader this year (I have a 12 year old PlateScope) and Techkon is the route I want to go. The All-Vision I believe is only necessary if the (process-less) plate has low contrast (not all do).
pd
scotts
pd
Out of curiosity, which don't? I've only seen a couple and they were quite low contrast. Although, I heard that one is in the process of making a newer version with a higher contrast.
SnoopDoug
So, a "process-free" plate that you have to process for clean out?
Couldn't you just as easy run the low contrast plate through a unit filled with fountain solution and water to clean it out?
Alois Senefelder
Hello "SD"
The answer is YES, just pass the plate through a Lo-Chem Plate processor or gently develop in a sink using Lint-free swabs and Water - then "GUM -UP" the Plates
Regards, Alois
RJ Litho
We have been running Kodak Sonora for 5 years and have not needed to use a plate reader. We find the plate to be very consistent day to day .We use Alwan print verifier every day so we can check how the presses are printing.This is also useful when you want to verify any new consumable .We run to G7 specs.We use it on the hp indigo to verifiy colour every day otherwise you running blind because we never get any proofs. We are running the plates on 2 - 40" Heldelbergs and 1- 73" Manroland .UV and conventional 200 LPI .
RJ
Jeff Duke
If you still have to do some kind of processing to the plates, why not stay with the process plates. Are they really “process-free?
It depends on how you define "processing" after plate imaging. Personally, I don't consider removing the unimaged area of the plate - either on or off the press - as processing the plate.
Color Optimized?
Ink
by Noel Ward, Editor@Large
Color is in demand in all types of documents, making color management a critical part of Digital Printing 5.0. Managing color on one device/press can be an easy task with the correct tools and processes. But managing color to ensure printed pages are consistent and repeatable across the different substrates and color gamuts of toner and inkjet can be a much bigger challenge. Properly implemented color management workflows can help achieve consistent color results across multiple devices. Although many end-customers are claiming satisfaction with “pleasing color,” two challenges are still in play. Link to Article
