I see your "Nooooooo!" and raise you....something.
I will SORT OF agree with you (given the respect I have for you, it would be foolish to completely disagree with you!).....this was sort of a long-standing debate in the G7 world early on...to linearize prior to determining tone curves or not. My "argument" for the case of applying a plate linearization curve prior to press curves is simply one of practicality.....when the G7 Curve software reports that my 50% dot should be a 46% dot, I want to be able to measure/verify that DIRECTLY on the plate and not have to go through mental gymnastics compensating for the non-linearity that the curve calculation software knows nothing about. Of course, if I could some how TELL IT what my "raw" plate curve actually looked like, giving it the ability to compensate for this and give me the actual on-plate value, I'd be OK with that....but for now the software I'm using assumes 50%=50% from the outset.
...and no disrespect intended.![]()
You give me too much credit
I did not have a good experience when I was on the GRACoL committee when G7 was being formulated and that has colored my thinking about GRACoL 7/G7. So I do not know the subtleties of the G7 method, however in the 2009 "How To" there is this paragraph:
"E.4.2 Pre-Linearized or Un-Calibrated Plates?
It is important to note that G7 press calibration can either take the place of, or be applied in combination with, conventional plate linearization. If the G7 calibration run uses “un-calibrated” plates, the G7 correction values will take the place of conventional linearization curves. If the calibration run uses “pre-linearized” plates, the G7 correction values must be applied in combination with any linearization curves, with both curves working simultaneously."
And then:
"6.2 Origin of NPDC curves
To determine the 'natural' NPDC curves of commercial CtP-based printing, G7 research analyzed
numerous press runs made with ISO-standard ink and paper, and a variety of plate types imaged on
“un-calibrated” CtP systems (no RIP curves applied, not even to “linearize” the plate).
5.4 Set up the RIP
Set up the plate making RIP exactly as you would for a normal job, but clear out any values in the
current calibration table, or begin with a new, empty table. The first press run is best made with ‘un-
calibrated’ plates – i.e. no calibration values in the RIP.
IMPORTANT: Do NOT linearize the plate-setter so that measured dot values on plate exactly match
original file percentages. Contrary to common belief, this may reduce accuracy of subsequent steps. "
This seems confusing in the light of what you wrote about the G7 curve software.
best, gordo
