Does anyone have a good definition of what a proof actually is. Example: "A proof is a simulation of what a printing press should produce ......." or something similar.
According to FIRST guidelines, it seems like there are different proofs for different reasons. And everyone needs to be in agreement which type of proof is being used and for which purpose.
All parties involved with a project must agree on the process and terminology used to evaluate and communicate color. Specifically, every proof created throughout the workflow should be clearly labeled to communicate:
- The purpose of the proof
- The system or device on which the proof was created
- Whether the output device was profiled, and if so, which profile was used
- The suitability of the proof for judging color
Concept Proof
This proof is common in the early creative stages of the project. It is used to capture input from all partners in the supply chain during design development and is also referred to as a “collaborative proof”. This proof is not typically color profiled. Therefore, these proofs should be labeled “Not For Color”.
Color Target Proof
The color target proof is often the selected “concept proof”. It represents the ideal color intent of the designer and client, independent of the print process or the ability of an individual press to achieve that color. Some of the color in this proof may not be achieved in the final print. To avoid rework costs and unachievable expectations downstream, it is helpful, when possible, to produce this proof based on the known or expected capabilities and color gamut of the anticipated printing process(es).
Comprehensive Proof (Comp)/Mock Up
This proof is formed to the shape of the final product and should indicate whether or not it is color accurate.
Profiled Contract Proof
The profiled contact proof represents the customer’s expectation of the printed product. The profiled contract proof represents the customer’s complete content and color expectations for the final printed product and is the basis for negotiations on project performance. It illustrates how the printed image is expected to look when reproduced on press and is an important quality control tool and communication device. It is profiled using a color management system (CMS) and is prepared based on profiles provided by the specific printer or prepress provider and is produced according to FIRST specifications. The contract proof does not have to be a dot-for-dot reproduction, but it must exhibit a common visual appearance to the press or characterized reference printing condition (CRPC) dataset. Therefore, it must simulate the dot gain/TVI, color attributes, detail and contrast of the printed image. It must also contain a control target that is processed and imaged as part of the proof, which will be used to verify accuracy and consistency throughout the design, proofing and printing process. The control target must contain specific screen values, which should be determined with the printer, for any colors printing dots, including vignettes. Although most digital proofing devices may not reproduce a conventional dot pattern, the tone scales should be measured using a densitometer (or spectrodensitometer) in the dot area function. Each one of the tone scales must equal the weight (dot area) identified by the press profile. Before a contract proof can be accurately used, the entire reproduction system must be characterized so that the proofing system is calibrated to match the printed result. Afterward, both press and proofing systems must be maintained for consistency and repeatability.
Soft Proof
This proof is viewed on a color-calibrated monitor. The soft proofing method can be used at any stage from concept proof to contract proof, depending on how well the system is calibrated. To use the soft proofing method, each party must have a color consistent monitor and a color management system (CMS).
