First let me say I haven't been running a press very long, so I am not that knowledgeable when it comes to sporadic issues like the one I am having.
I print short run letterhead jobs a lot; most of the requests are for very short runs 500 to 1000 at a time. I have in the past ran a bunch these jobs with the same logo back to back and only changed the plate with the address information as that was the only thing different between the various letterhead jobs. Recently the logo changed and now there are very fine knockouts in the logo, and I am having a problem with the images getting out of register in the print run in the first 500 or so, basically the whole job I am chasing the registration up to 1mm in the first 500. Here is the thing, it doesn't do it all the time, and so I am having a hard time figuring out what is going on. I am not sure if this is because I am not changing the both plates each time, or if the packing is off and that is causing stretch, or if it is because I am using poly plates instead of metal.
