Ricoh 9210 Registration Snafus
famerdave
On our fairly new Ricoh 9210, we have having lots of problems with registration on heavier weight papers. (300-350gsm)
We run the Auto Paper Registration, and after the 31 test sheets, the test print looks perfect. No skew or registration issues at all. But once we send a file from the Fiery, it's off 1/4 inch consistently. We did confirmed in Fiery settings that no image shift is being applied, which leaves us to believe it must be some machine/Fiery connection issue?
Has anyone else experienced anything like this?
I have a 7210 but assume some things are similar.
1. Always make sure you clean the inline scanner before running the routine.
2. Per each profile, set the registration function for HIGH QUALITY under advanced settings, this requires 35 sheets.
3. I assume you’re doing this, but make sure you are applying and saving the adjustments per profile.
4. Confirm that your paper is consistent - some heavy stock I notice can vary up to 3/16” per sheet. Finch 130# uncoated cover, is one of the worst examples that I buy, but I print a lot of business cards on it. So I cut and back trim it down to 12.8x18.8 so every sheet is uniform, and then I create a special profile for that on the printer.
5. If you are off 1/4” consistently, note that you can also apply a further manual adjustment on the printer to your auto adjustment, which should help close the gap on any troublesome stock.
If the grain on heavier weight papers is wrong it will affect registration but in my experience it isn't consistent through the run.
When you say it's off by a quarter inch - is it uniform? I.e. no skew or anything just not aligned as you would expect?
Sounds like a setting somewhere in the fiery if so.
Same issue on our 9200, ours is out by approx. 2-3mm only happens on 300-350gsm SRA3 or Banner sheet thicker, the alignment sheet is 100% perfect, then put the job on and its out
the 31 sheet doesn't make any difference i have tested between that and changing it to 10 sheets and it makes no difference
I had similar issue too, only when printing heavy solid coverage, the paper became slippery, and the 2nd side image came out about 1-2mm smaller. increasing the ptr pressure sometimes helps
Yes I have had this issue on all stocks. My file prep person makes the adjustment and resends the file or you can turn "imaged shift" on in the finishing tab and make adjustments to front and back to the X and y coords. There is a manual shift adjustment under the auto registration 31 sheet adjustment as well
Oh it moves after you print like looses registration. Sorry I have not had that problem. But I'm thinking......???
I also have this issue, and have been told it is normal on 300gsm + (i do have to say our 100-150gsm stocks are perfect and never need changing ,
we also have the issue where a double sided aligned stock , will print differently if you print it single sided to double side, anything upto 5mm movement on the back side
31 sheets is ridiculous - change it to 10, it hasn't made any difference to our stock alignments for the last 2 years -
We are currently experiencing front to back registration issues across multiple machines (9200 and 9210). Our tech have been unable to resolve the issue. Machine has parts that have been cleaned. Parts have been replaced such as the registration unit. Paper library has been rebuilt. Does anyone have an suggestions to resolve the registration issues that have worked for them?
Having a 9210 i too have these issues. Something we try to do is use the same paper from week to week to help keep the adjustments we do make. However my tech did finally "Do some research" and found out that thier is a calibration to be made at the registration unit. It involves a template physically placed in the machine from what i was told. This has yet to be completed on my machine but should be very soon. Another big problem for us is Magnification of image its off daily and was basically told that oh we are running " custom paper" and its to be expected. So anyways i will update when my tech does finally come out and make these adjustments.
