chevironjr
I recently took a part time position on a Ryobi 3302. This particular press slings big globs of ink onto the plate and blanket when it stops. I have never run into this, has anyone else, and if so how do you stop it?
When we have ink "dripping" from our 3302 it has been because of ink buildup on the frames crossbars which run from 1 side frame to the other and are right up next to the rollers. You normally need to remove the rollers to get to them. We normally need to clean the bars off once a year. We remove the rollers and that gives us access to the cross bars, then we use shop rags and blanket wash to clean the ink off. Sometimes we will start by using an ink knife if the globs of ink are real thick and dry. We have 3- 3302 presses and they ALL do it, but once clean they will run drip free for a year or more.
